Oil Filter Relocation Needs 0.o
Get new hoses yet? ^
Yes I did, thank you!! Yesterday
What do you need if you remove the adapter to go with the 2 wheel drive style oil filter mount?
I am assuming an oil filter base of some type.
Any pictures or anything anywhere?
I have the 4 wheel drive truck here and was going to pull the adapter and clean it. I just wanted to throw a filter on it with the front drive shaft off, for the time being. Until we pull the engine, then re-install the filter adapter on the 2 whel drive engine - which is not here at the moment.
So since this thread was renewed, any updates on the relocations?
I am in search of a solution for my 4wd rigs, I really hate 4wd oil changes... and 4wd for that matter... :)
Some of them are used in cold weather, so cold weather flowability is important.
I am also fussy on fit and finish, so no cobbled shit. :)
Remote filter was among the first things I did to the Burb when I bought it as the filter change was a *horrible* experience.
Installed a dual (bypass) filter back around the X-fer. If you do it, plan on going to a hydraulic shop for extra hose (of the two installs I have done, both needed more hose than came in the kit). Also, consider getting a wrap for the hose to protect it from chafing. Got my wrap from Parker when I got the hose and that stuff is very tough and yet very flexible (almost like extra thick panty hose).
With the remote filter, changes are *very* easy as there is plenty of room to work.
Am using the Amsoil dual housing. Do not remember the hose sizes. When I needed the extra hose, a quick call to Amsoil's help desk got me the information that I needed.
Here as the Amsoil parts list I used for my remote install:
> BMK23 Bypass kit
> BK296 Adapter Plate
> EA026 Full Flow Filter
> EABP100 Bypass Filter
The kit comes with one hose which can work depending on where you want to mount the filter housing. Seeing as I installed my filters back under the cab, I needed to buy a second hose.
If you do go with Amsoil's kit, for the 4WD 6.5 vehicles can probably remove the 'elbow' housing on the block as it is not necessary anymore. I still have the elbow as the shop left it on (and then transfered it from the 506 to the P-400) and have not had the initiative to go in and remove it.
