Oil Filter Adapter 0-Ring Swap
Matt Bachand
Depends on the 6.5
Worcester, MA
Turbine Doc did an excellent pictoral on the place. I recommend it to everyone. This job wasn't that bad at all. I couldn't believe how 'square' the old orings were, they felt like hard plastic squares.
Re-installed with a fresh oil change and no leak there now.
I also engine cleaned the entire underside of engine with degreaser and roll of shop rags.... Looks nice now, and didn't take that long .. I got all into the truck today :)
I did see the factory Oil cooler lines... I touched the safety clip and it crumbled in my hand :(... So I left it alone, zip tied across to a stud and i'll put that on the to-do list.
I can see how much easir it would be w/out xover pipe, so i'll prolly change those at the same time as the cooler/SS lines.
I bonded with the underside of my truck today. Gonna try to make it leak free.
Once again Turbine Doc, Thank you very much for your work here.
