bison
You could be on to something altough the feed for the center turbo most likely originates from the camshaft and the bigger hole is prob the turbo drain( i aint familiar with the center mount turbo).
The second oil hole may lead to the OPS bore having gone trough the turbo.
You still got the plug back of the valley you can use for the OPS/Gauge me thinks.It used to be the OPS spot on the pre 96 blocks
I just looked at the pic,there is only two holes,so what i said dont apply.
The turbo drain me thinks wont be pressured,just free flow down the pan.
The oil to the crank comes via the cam shaft gallery.
I hope you put the Cam brgs in correct and did'nt block oil passages ?
