ak diesel driver
6.5 driver
those are the stock lines. Aluminum tube attached to rubber lines
That's weird they don't look like the ones AutoZone had... I wonder if those idiots pulled the wrong ones off the shelf..lol
It's not the "hose" that fails, it's the "c" clip thing that holds them in at the block, it is small and will break and the line will pop off...
eXACTLY THE REASON i JUST ORDERED KITS FROM Leroy.I do get what you're saying but in my case the hose shop would do no good...Because I have to take the hoses off the truck for them to know what they're making.. So once I take the hoses off the truck I can't get to the hose shop and they may not be able to make them while I'm there in which case then I'm really up the creek.. I just didn't think it would be that difficult to figure out what all is needed.. but such is life
Just order the kit, with the cooler and ask for both sets of fittings.
I have never seen a link to the exact fittings needed and the length of the lines posted up. I have seen links to the coolers with the 1/2" NPT fittings
