matuva
Tropical 6.5er
We're on the way to install a Ted's 6.2l in a 1997 K1500. Everything is going fine, but we forgot one thing: the 1997 K1500 uses high flow hoses which are bigger than the oil lines found on 6.2l and early 6.5ls...
Soooo, we have to match the 1997 oil cooler lines with the smaller oil cooler line connectors found on the 62l...
We so need connectors which can bolt on the 6.2l block (3/8 if I'm correct), and can receive the 1997 cooler hose , 14 NPT x 18.2 mm on the hose side.
Of course, we could cut and weld, but we like to have nice parts if they exist
Any body knows if such connector exist, where to find them, part #?
