Turbine Doc
Just Another Diesel Guy
Matt where is your vac monitor located in the system, inlet of your lift pump or IP inlet after filter I have one as you know on outlet of each of my filts, really all you need to know something is wrong with fuel delivery is have one at the outlet of the filter mgr, that is the one that comes on 1st with mine, which stands to reason as it is a lower micron rating than my racor and would sense flow restriction earliest as it has the finer media.
If the racor or the tank sock get cruddy filter mgr trips my switch/alarm LED as IP is struggling to get fuel, I also see it on my in cab gauge on hard acceleration when my IP inlet pressure gauge starts spending a lot of time @ near 1 psi.
