ak diesel driver
6.5 driver
I will definatly be watching for your post. Thanks in advance for your efforts.
Jacob,
Read your PM's. Everything you are reporting looks good. As an FYI, factory specs are -.50*. The magical TDCO is -1.94*. Anything in between is good to go. In my opinion, -1.41 is good and I wouldn't mess with it. You don't have enough mods to justify messing with turning the IP to get -1.94*.
BTW, I never use the "disable" button in the tool. It doesn't work. When I get the setting I want, I just shut the truck off. That is what the how-to document states. As a matter of fact, you don't have to click any buttons; just a click of the window will cycle through the ranges. I probably should put this bit of info. in the doc.
Are you saying that clicking on the window that displays TDCO will cycle through the possible ranges the PCM can control? I noticed it sometimes changed when updating.
Quomack, I've been reading alot of your threads, I remember you saying in one of them that you never turned your pump. Did you end up turning your pump to get -1.94? I'm going to assume you did. It shows me having a timing of 12*, but in TDCO Learn sometimes it drops to 3* or so.
Also, have you ever used the Timing Set mode? What would that be for?
And that 'disc' looking thing at the top after the enable/disable buttons, ever figure out what that is for? Seems you can move the red dot around, not sure what effect it has.
Using 02 6.5 L65 made everything including cylinder shut-downs to function. The 97 L65 I could read data, but not use the enhanced testing procedures for some reason. Now I know to use the 02.
Have you ever found a forum or FAQ or anything of good interest to read about this software?
