- Staff
- #21
Unplug the ABS and see if you can read the ECM then.
Sounds like your ABS module is bad. It is replaceable seperately from the ABS pump unit. When you take the screws out of the plastic cover on the ABS unit, it lifts off of the pump unit. I know this was a common problem for GM on the 99-02 trucks because they mounted the ABS unit under the cab, and water would get splashed up into them under the truck. It looks like from the catalog there is 4 different ones that could fit it. If you go to a boneyard and find one from a 99 SUBURBAN, TAHOE, YUKON of the same body style, it should work.
Your problem is the 95's ABS module is OBD1, not OBD2, so you will not be able to read codes from it if there is a problem with it. 95 was a 1 year only, then 96-99 was OBD2. Same basic module, just used OBD2 instead of OBD1. Also being OBD2, I don't know if it will correctly illimunate the brake and ABS lights as the wiring may have changed with the change to obd2.
Was code reader communicating while the 'new' ABS module all connected up or disconnected/unplugged like the old ABS Module?I picked up an ABS module from a '99 K1500 Suburban gasser in a Pick a Part boneyard. Installed it and it did not solve my ABS problem, but my Code Reader still communicates with the OBD II.
I think it's just something with GM ABS. I borrowed a TECH 1 to scan my ABS when I was having a problem, and it wouldn't connect to mine. Ended up doing it the paper clip way, and read flashes of the light to get the codes out.Everything connected up with the "new" ABS module and the code reader communicates with OBD II.
Pretty sure it will pass as is. No codes and running great. The only subjective part is the acceleration snap test where I do get a puff of black smoke, but it's not bad with the GM Turbo.
Still want that ECM from Browning for insurance in case I don't pass the snap test.
I tried to pull ABS codes, but same as before with this Code Reader. It has ABS capability, but not for GM Trucks in 1999. Gets to the level where you select the 4th or 5th Cahracter from the VIN# and "K" is not an option.
Which pins do I use for the paper clip? What's the flash sequence?
What he said. One of the reasons I'm glad mine is a 95 is the ABS and airbag is still OBD1, so it was all stand-alone from the factory. OBD2(96+) is all mandated to use a universal conenction, and universal data protocols, so no more self diagnostics without a scanner of some sort.paperclip only works on obd1
Check, er ECM is in the mail (UPS actually). I sent it to the cabin at the lake to give you an excuse to go play in the snow....joke. It will at the house Friday.
