O-ringing the block
SnowDrift
Ultra Conservative. ULTRA!
Central Ohio map dot
I'm trying to learn about the subject title. I've only heard about it and ready very little. It looks like Quadstar has a tool for the job, but I didn't understand until recently what it even was. Is there a downside to this process?
Is there a concern from dissimilar metals in contact with one another, with the copper touching the metal of the block & head? How is galvanic corrosion mitigated with this type of setup? Some use stainless steel for these rings, as I've seen.
Since this is a consideration, is it safe to say that a gasket isn't already made with this type of feature integrated for our particular engines?
Here is a thread where it is discussed, but a search didn't turn up much information on it. Perhaps there are different terms some use for the same idea?
Here is the article I ran across when I was first trying to learn about it a couple months back:
This describes the process in the event someone is unfamiliar like I was (although I am still learning):
