bison
Do you guys have right thickness clutch plate?.
To thick a clutchplate will bring the diaphram/clutch fingers closer to the flywheel and as a result the fork will pivot further towards the tranny. maybe the slave doesn't have enough travel left to disengage the clutch.
If the master cylinder does not bottom out with the pedal up it can't bleed the air out and refill with fluid.
A master cyl that leaks back under pressure between the piston and tube will impair/shorten the stroke of the slave..
