ak diesel driver
6.5 driver
One of the things you guys in warmer climes need to realize is that you can never have too much covered storage. That's why Simon's shop looks crowded. Anything he doesn't want ruined has to stay under cover.
x2
My lot is so small an aerial shot of my place would be almost nothing but rooftops and tarps.![]()
x2
Looks like a working farm shop, Bison! I like the woodburner!
Shipshape Barry, shipshape. Absolutely no offense taken. My shop(s) have to have everything where it should be or when I need something right freaking now I'll go nuts. Anyone who farms part time like I did for years knows that the more time it takes you to fix something is less time for field work and you DO NOT have the extra time! You have to go to your regular job so you can waste the money :mad2: farming part time...Oh, come on Mike, admit it.You are a neat freak!!!:grouphug:
I used to farm fulltime(stupid beef) and work parttime to make ends meet,wich never did anyway.Shipshape Barry, shipshape. Absolutely no offense taken. My shop(s) have to have everything where it should be or when I need something right freaking now I'll go nuts. Anyone who farms part time like I did for years knows that the more time it takes you to fix something is less time for field work and you DO NOT have the extra time! You have to go to your regular job so you can waste the money :mad2: farming part time...
I found i always pulled the short stick helping neighbors using my shop to fix their own,missing tools,using supplies(bolts,nuts ,welding rods etc)without replacing them.Only "favors" in return where the use of pieces of equipment that i had to fix first before it could be used.:rolleyes5:I have made a number of friends in the same (shop) boat as you Bison. If they needed to use my shop for a repair in bad weather it was all theirs as long as it went back to it's neat normal self when they were done. Most times I was more than willing to lend my mechanical/fab skills and materials to help them get back to work. I knew they would return the favor if I ever needed help.
You keep cats around your shop? They sure keep the mice down by me.
Thats the beauty of living out in the bush.We ended up buying this fixer-upper home summer of '07. It had a 1 car garage that faced the alley. My first project was to turn it into a 2 car facing the main road. It's a small lot so I did a ton of measuring my "driveway" to maximize space use and make sure I didn't screw myself somewhere in the long run. Built the whole thing by myself. Only help I had was a friend coming over to help pick up and place the overhead beam (size determined by friggen county P&Z...wayyy overkill). My power is still supplied by 2 extension cords coming from the house :rolleyes5: but I'm planning on fixing that remedy next summer. I can then at least use my welder again :thumbsup:
somehow i dont feel so bad nowHere's a pic of what I have to work in right now. At least until I get moved into the house. 16x30 plus it has my standby genset inside too. I had to open the door to get this pic. Put new ball joints on the pass side and tie rod ends on both sides. I had to roll the front of the truck sideways with a floor jack to get enough room to work on one side then roll it back to work on the other
If being in the cold would cause a pneumonia,i would be sick all winter long.:smile5:Wow, you guys have some cold weather. I am feeling the 24*F here in the Atlanta area this morning and I feel like a woosy. This is a heat wave compared to what some of you have.
Since we are on I remember. I remember laying in the snow removing the starter out of my car, repairing it, and reinstalling it. I didn't have any garage and that really cost me a serious case of pneumonia.
