Nor-Cal Nick 2008 LMM Dually build
--------------------_
DONE !!! :hurray:
Hope you like these ,,,,
That's very nice.I cant quite afford all this stuff yet but will hack away at it little by little.Got the Shackles they work great-pulled my 5er(13k pounds) a few hundred miles and through some pretty rough off road places and no problems.And I hit some terrible wash board roads and the shackles held up great-made the rear track a lot better.
So for those who are asking about towing with these on -the answer is they work great.
No mods on truck with full load 13k- 5er ,8.7mpg.Came home empty without 5er (left in storage) got 16mpg going 75 mph the whole way, 250 miles.
I finally had a night to post up some new pic's of my truck of what we ended up doing to it for the 2008 SEMA Show in Las Vegas this last November. I had posted on a few forums looking for idea's and it was pretty much a land slide that the way to go from what members what'd to see was the route we ended up going, Cognito 4" NON torsion bar drop style lift kit and BLACK wheels on 35's. We also had a big twist (in my idea's) when Chris & Moe @ ORU presented me with the idea of running there Defender roof rack. You guys have to know this is pretty much the smallest lifted truck I have owned and my personal builds don't really flow in the scheme of a "Roof Rack". So I put it out there and alot of people from what I felt really liked the idea. So with what I see changing (Style's) over the time I wanted something new so I took them up on the offer and the Rack, Black wheels and the whole tow/off road truck look started coming together. At the VERY LAST minute I send emails out for lights and reachieved a email back from Chris @ Baja Designs (SolTek). These guys make some SICK LED lights and the new product off road is LED lighting so I had to have them. Chris red labeled lights out to us and we installed them on the Defender rack.......MAN that just set the rack off for me and I loved it!
I want to thank a few people that really helped out on this build:
  • Justin, Chad and the whole crew @ Cognito Motorsports
  • Chris & Moe @ ORU
  • Toyo Tires
  • Fox Shox
  • Mitch @ Titan Tanks
  • Truck Covers USA
  • Sulastic Shackles
  • Chris @ Baja Design (SolTek)
  • Roland & Christi @ RBP
  • Pete DAWG @ Billet Clamps
  • Troy @ Tri Valley LineX
  • Edge Performance
A BIG Thanks goes out to my guys here at Nor-Cal Truck for putting up with my crap and pushing them to get the truck done!!!
  • Jeff (Navvy)
  • Jeriah
  • Berry
If you have been following my truck build you see we started with a leveling kit and now changed to a Cognito 4" lift, so we have changed a few other things as well. You can look back in this thread to see some of these parts being installed. Here is the current list of product being used on my truck if you would like to know:
Cognito Motor Sport-
  • #FSLK100401 - Non Torsion Drop 4-6" front susp. lift
  • #UCAK100001 - Upper control arm leveling kit
  • #DSHK100002 - Dual shock hoop kit
  • #PISK2008 - Pitman & Idler steering braces
  • #IPAWG8 - Idler Pivot assembly
  • #TRK100045 - HD Tie Rod kit
  • #SBELKHD-1004 - HD Sway bar end link kit
  • #SBK100046 - Rear Sway bar kit, over the frame
  • #TBKE60 - Traction bars
Tom Federico
  • #8181 - Front sway bar
Sulastic-
  • #SA-04HDD - Rubber spring shackles
Fox Shocks-
  • #980-99-030-A – (Front) Fox 2.0 Pro Series 6.5' Remote Res. Shock - .625 shaft
  • #980-99-039-A – (Rear) Fox 2.0 Pro Series 11' Remote Res. Shock - .625 shaft
Billet Clamps-
  • #? - 2.0"x2.0" Black Thin clamps
Airlift-
  • #57275 - Helper air bags
Eagle Alloy-
  • #097 & 098 – 17” Dually wheel (Powder Coated Black)
Toyo Tire-
  • #360310 - 35X12.50R17 OPEN COUNTRY M/T
Freds-
  • #? - 3” Rear dually wheel adapters
AFE-
  • #75-81332 - STG. 2 Si intake kit
BD-
  • #1041460 2001-up Duramax Manifold, Exhaust
MBRP-
  • #S6020AL Alum 5” Turbo back exhaust kit
RBP-
  • # 6” BLACK exhaust tip
EFI Live-
  • #V2 Duramaxtuner.com as tuner
Auto Meter-
  • #17118 07.5+ Chevy triple pillar
  • #6400 Nexus 8 Channel module
  • #6445 Nexus Exhaust temp
  • #6470 Nexus Boost
  • #6457 Nexus Trans temp
Edge-
  • #25230 - Evolution CTS touch screen
Nicktane-
  • #FKIT-LONG Duramax Fuel Filter kit
  • #? 5/8" upgrade to match TTS lift pump (A NCT upgrade)
TTS-
  • #? Duel Fuel Lift Pump System
  • #? Billet Fuel pickup & Hose
TransGo-
  • #? Allison Shift Kit Jr.
Mag-Hytec-
  • #A1000 Allison Trans oil pan
  • #29537965 Allison Deep sump filter
  • #AA14-11.5 AAM rear diff cover
Gears-
  • Front and rear 4:56
ReRoute-
  • #? - PCV Reroute kit (Tony B.)
Titan-
  • #7010301 Titan Super Series 62gal. long bed fuel tank
H.I.D-
  • #H11 6000k HID Conversion kit
  • #9145 6000k HID Conversion kit
Amp Research-
  • #75126-01 Electric steps
  • #75131-01 L.E.D light kit
DrawTite-
  • #40259 - 24k Signature Series Fifth Wheel Trailer Hitch
  • #30082 - Signature Series Fifth Wheel Rail Kit
Ryno Mfg.-
  • #? Billet “Patty” ant. (BLACK)
Window tint-
  • 55% - Front Windshield
  • 5% - Sun Roof
  • 5% - Front driver & pass. window
  • 20% - Over factory Rear windows & Slider
RBP Grill-
  • #251113 - Chevy RX Series Studded Frame *Black*
Defender-
  • #40504 - 4'x5' 1 Piece welded Roof Rack
  • #AM-8 - Clamp Kit
Baja Designs-
  • #62-0200 - Soltek LED Headlights (Driving)
  • #62-0200 - Soltek LED Headlights (Flood)
  • #62-0200 - Soltek LED Headlights (Wide)
Truck Covers USA-
  • #CR200 - Chevy Bed Cover
  • #T317-B - Keyless Entry
  • #? - American Cargo Lights
LineX-
  • Tri-Valley LineX Long Bed (w/Extra)
Nor-Cal Audio-
  • #NAV2GO - NAV over ride
  • #BFGM - Blue Fusion
  • #BFGMH - Harness
  • #bfgm-ipod - I pod adaptor
Here is what we found when the front axle was pulled out for the lift kit and gear install. This was the aftermath from this @ Pismo .....
http://www.youtube.com/watch?v=CtSBb5dn3-o
Tell me what you think.
The words aren't coming to me to describe how absolutely badass that thing looks right now. I love those wheels...hell I love the whole truck.
EXCELLENT BUILD!!!
A few thoughts come to mind. It takes a place to do the work, the time to do the work, a pile of money and a LOT of talent and ideas for this build. Congratulations building one badass dually.
Looks good! I like the tires and the lights on top.. dont like the star on the grill.. very nice none the less :thumbsup:
Ha, I knew it was only time till you saw the beauty of black!!:thumbsup:
I still got one up on ya though, The Leslie horns are funnnnnn!!!):h:eek::D
Peace
