no start after electrical work
alkmisc
VT
Problem: Explain your problem in concise language
I've had a couple of no starts recently, both times after doing some electrical work that I've not been able to figure out. I disconnected the batteries both times while doing the work.
First time was a couple of weeks ago after I replaced my glow plugs and glow plug harness. The starter would crank but the truck wouldn't start. I went through checking the grounds, lift pump, etc. Eventually, the truck started after replacing the fuel filter. The truck set a P0380 glow plug code that later went away though did come back at one point. The glow plug controller was not replaced and may be original. There were no starting issues prior to the work (other than what you'd expect with quite a few non-functioning glow plugs).
The second time was today after I installed a Kennedy headlight harness. After connecting everything back together, the truck wouldn't start again. Eventually, I scanned for codes and there was the P0380 code again. After I cleared the code, the truck started right up.
- Year: 1999
- Truck model and class (ie: c2500) K1500 Suburban 6.5
- Automatic or Standard auto
- Mileage: (indicate miles or km) 141606 mi
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) IP/PMD at 131651 7/2010 due to P1217 code, trouble starting (fixed after fuel filter change), and one spontaneous shutdown
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? F turbo
- Ambient outside temp: (indicate *C or *F) 30-55 F
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) #2 diesel
- What fuel additives are you using? powerservice
- Where are you located? VT
- Air filter 129230
- Fuel filter 141426, 132277 before that
- CDR Valve? unknown
- Coolant – last flushed/replaced at unknown
- Oil – synthetic/regular, changed at 139046 9/2011, synthetic
- Batteries – state of charge, (matched set) replaced at 10/2011, 139946, charged and matched set
- Battery cables and grounds (removed, cleaned and tightened): 141426
- Glow Plugs - how many miles on them? 200 mi What type? Kennedy
- Injectors - last changed at unknown, may be original
- What were you doing when it happened? see above
- How was the truck running fine before this problem appeared? fine
- Has this problem ever happened before? see above
- Describe any related factors that might be part of the problem. ______________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) Y And? P0380
Diagnostics:
1] Starting:
1a] Does the engine start? _________
1b] Does the engine crank over? yes
1c] Are your batteries fully charged? yes
1d] Have you removed, cleaned, and tightened all battery connections? yes
1e] Does your Wait to Start light come on for a time? How long? ~10 seconds
1f] Does your glow plug light come on? 1e For how long? _________
1g] Do you see smoke from the exhaust while cranking? What color? whitish gray, only wisps when it doesn't start; no real smoke when it starts as it should
1h] Does the Service Engine Light Glow during Start/bulb check? yes
2a] Can you hear your lift pump working? yes
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? yes
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ___________
2d] Loosen an injector line and crank the engine - does fuel come out? _________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? yes
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) pump
3b] Condition of Extension harness (if used) Vendor or Homemade? _________
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. cleaned
3d] PMD Make: looks like a flight systems, came with IP
3e] PMD Age: 1.5 years
4] Stalling Issues none
4a] Do you experience stalling only when hot? ____________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) ______
4d] Is stalling momentary (engine recovers)? _________
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? _______
5b] Any bubbles or oil film in coolant overflow tank? no
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? no
5d] Excessive white smoke from exhaust on cold start? not since glow plugs replaced
5e] Excessive black smoke from exhaust under hard acceleration? no
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? no
6c] Have you added a performance PCM (reflash) or Chip? no
6d] Have you changed exhaust / downpipe / crossover? no
6e] Wastegate – mechanical or vacuum (OEM)? OEM
7a] Single or dual thermostats? dual
7b] Have you replaced them lately? Manufacturer of replacements? no
7c] Have you pulled and cleaned Radiator and coolers lately? no
7d] Have you replaced the fan clutch? Manufacturer of replacement? no
7e] (winter) Have you tested your antifreeze? Good to what temp? __________
7f] (winter) Are you using a winter grille cover? no
Security light also comes on for ~5 sec at start up then goes off.
if I read your post right the PMD is still on the IP? If so that's the first thing I would check and the second would be your GP controller
I've got a spare PMD waiting for some intake gaskets before I remote mount that (can't quite get it unclipped with the manifold in place).
How would I go about testing the GP controller? Would I just be looking for continuity during the glow cycle? The WTS light is at least coming on when it should for the initial cycle and afterglows and the truck starts pretty easily on a cold morning unlike before the glow plugs were changed.
For taking out the stock PMD harness as suggested above:
1. use small medium length screwdriver to unclip the connector towards the back.
2. use a coat hanger with small hook to fish it out towards the front under the manifold.
3. once out, you can hook one end to the pmd extension cable, route the extension towards the bumper.
4. connect it to the PMD in the bumper (should have fasten/bolt it somewhere so it will not fall when you drive).
No need for a new manifold gasket.
So, 1999.
You've got passlock.
It would be obvious if it was the problem, but you don't have a "security" light illuminated on the dash do you?
Is it starting at all now or dies it just stall out?
It's possible the PCM lost the passlock value when you had the batteries disconnected if it was for a long period. A "relearn" would fix that if it is your problem.
Not likely the PCM dumped the values, but possible....
So, 1999.
I was wondering about that too but the "Security" light goes on for ~5 seconds then goes out like most of the other dash lights. The starting issue does sound something like it could be Passlock related if it wasn't allowing fuel to flow. I did try a relearn at one point but no dice after that. There were no starting issues last fall when I was replacing my battery cables and the batteries were disconnected.
Right now the truck starts fine so I wonder how intermittent this problem may be. In both cases, once the truck started, it doesn't seem to have any trouble starting again. I think I'll disconnect the batteries this weekend and see if that'll reproduce the problem again.
Stalling is not a current issue.
One other thing, when the batteries are disconnected the glow plugs won't work for the first start. It's that way on obd-1 anyway.
Here's the lastest installment. Truck started fine several times. Then I went to start it today but wouldn't start. Scanned and cleared a P0380 code, still wouldn't start. Did the Passlock relearn procedure and it started, no SES light. Drove for a while and then parked for a while, restarted fine but now has SES light lit. Shutdown then restarted again and restarted fine. Now it's parked for the night and I'll see what tomorrow morning brings.
I'm planning to replace the glow plug controller to take that out of the equation. Still trying to get the PMD harness unclipped (tried a couple of screwdrivers and two different pick tools and still can't quite get it).
If Passlock activates, will the Security light actually show anything or does it just flash or light up if there is a malfunction in the system?
Security lights up for both wrong password values and system malfunctions.
Depending on what the fault is, and error code might be set.
Although, your returning p0380 seems to indicate something else might be going on....
Replacing the glow plug relay fixed the problem. Definitely not the original relay either - the inner nut holding the relay was missing. Turns out the relay was working more and more intermittently.
