Woody35
Active Member
SHE CRANKS AND RUNS!!!!! thanks for all the info. i did the battery bolt mod and it worked. jifaire you were right. the same thing happened to me that happened to you at the campground. thank you to all that helped!!
part of every 6.5ers tool kit should be one of these, removes a lot of guessing fast if batteries are good or bad, and you can test with batts in truck
