foxdenfarms
1994 C3500 6.5TD
Ok newbie here newbie to diesels and the 6.5. I will update my signature as soon as I figure out how to. I have a big problem, my truck is a 1994 c3500 crew cab flatbed, mechanical wastegate, cone filter, lift pump on switch, straight pipes, boost gauge. Motorr has less than 100k it is a documented Jasper engine that was put in at around 95k truck has 174k on the clock now.
Now my problem...
When I bought the ttuck on the way home if I had my foot on the throttle above 1500rpm the SES light would come on the go out when I let off. Replaced the vacuum wastegate with a home made mechanical one, replaced the filter and opened the exhaust and it runs great! ....But...
Under WOT in o/d at 60 or so it kicks back and looses all power and boost and throws code 36
When truck is shut off and restarted it goes away but when all power is lost boost wont go higher than 3 or 4 psi and has no balls. I read up on code 36 and what I am reading just doesn't make sense.
The truck also sometimes when started and placed in gear will not move or rev just bogs and have to put it in neutral and rev it the back in gear and once you're rolling you're good.
Thanks in advance and I will update as soon as I figure it out. I dont have a computer so im working off my smart phone and I have big fingures and a short attention span...hahaha
Now my problem...
