New to EFI Live questions coming soon...
Also, Just FYI - When you open up the tuning tool, goto "Edit", "Configure Display Units", Select the button for "all" (all the selection will be highlited blue") and then press the "imperial" button.
It'll all make alot more sense to you then! It was a painful few days until I found that trick, it turns everything back into American :D
Was your speedo correct when it was doing that? I'm just wondering if the input sensor said one thing, and the load sensor from your pedal said another... Not sure though.
honestly it just feels weaker than the edge when towing...although it is so much smoother all around...Guy said it somewhere between level 1 and 2 and I towed on level 2
sometimes level three...but even on level 2 it didn't down shift like it does now...He told me he'd work with me to refine it originally, so I guess I'll ask him to bump it up some(I already did but got no response yet)
I think maybe he went conservative on it only because I had limped my tranny once when accidentally towing on level 5 (didn't know it was on 5 and was pouring it on when passing someone who pissed me off)
we'll see what happens...
Oh and I searched the efi forums already...could not find a fix for that nag...some said just make sure you have it plugged in...whatever...thats not what it's supposed to do...
Thanks for all the help tonight...but I think I'm gonna hit the rack...I got three days of rain coming my way from that bitch fay...
Ohhh, Also in Maximum boost pressure, or anything to do w/ boost pressure, it's baro pressure PLUS the boost pressure. So don't freak out when it says something like 40 lbs and you're boost gauge only shows something like 24 lbs...
Yeah, it used to not pop up on me like that, we'll find it and fix it!
Take care, be safe and best wishes for no rain/slight mist rather than a downpour!
