docdray
Oompa Loompa
I don't believe you can high idle a 98 burb???, I whole-heartedly agree, go with HEATH, nothing I bought from his ever had a problem. from SS, I had a new duramax fan clutch go bad in a month, and coolant upgrade I had to modify to make work. Granted I never called SS to straighten out, I cut my loss, and moved on. Exhaust--beware Jardine-over month to ship and parts nowhere near working together. I ran new down-pipe and 4". Get rid of cat and I recommend just using a medium, straight through resonater to cut the rumble/ humm in the cab.
do:
fill out signature then
1 Heaths recommended radiator clean
2 change tranny fluid and filter
3 change rear differential fluid(if 4wd the xfer and front diff)
4 check cdr
5 if 4wd, check front hub/bearigs- see Turbine Doc's issue
6 as mentioned-Battery cable mod
7 check out heathdiesel.com
8 most important-read, read and read this sight, saves thousands on repair.
9 many more preventative measures.
oh yeah, read about wastegate solenoid-as mentioned Heaths TM and chip as options.
10 mpg is low, mine gets 11.5 with 9k lbs behind it. check lift pump and fuel filter. with that mileage, injectors possibly soon. clean intake, etc, etc, etc.
do:
4 check cdr
