buddy
Active Member
Did you run a TDCO learn when installing the Heath PCM? Can do with KOKO method, if not that would be the first thing I would do, it might clear things up. Its required anytime swapping a PCM. Not when swapping OBD1 chips, but if you swap the whole PCM, CPS, IP, or timing chain
You could experiment by retarding the IP physically, and not resetting the TDCO after that. Then it will be less advanced than the computer thinks it is by the previously stored TDCO value. If you then run the TDCO learn it will just know its retarded and move the stepper motor to achieve the same programmed advance value. So to fool the PCM you move the IP without setting the TDCO. This I only recomend as a diagnostic method, and not to run it permanently like that.
