buddy
Active Member
There is a large camp of people that upgraded to a TM before they ever paid the bigger bucks for the PCM update. The TM outperforms a stock boost curve for most people, because the PCM cuts boost a lot. But it could waste more fuel if they set their TM too high and were driving with too much boost at empty cruising speeds. Simple solution is to loosen the TM, but then that awesome spooling you had is not as awesome, but alright. When I was using the vac system it would do everything how I wanted it, fast spooling because it held it shut, doesnt give until youre over the programmed boost, and it could be programmed pretty high, but then at a lower fuel rate and cruising RPMs you can program it to cut boost to good cruising levels. Vacuum costs more to maintain, but I liked it better. I only ever had to repair a few vac line cracks, but other have failed pumps which are spendy.
