New product
Twisted Steel Performance
Pauline, SC
New product release........
TSP 10 bolt Halo Girdle
Complete using ARP 2000 studs, laser cut 3/8 thick A572 steel, tool to torque outside bolts when installed.
This first for the 6.2/6.5 diesel will fit ALL blocks and uses the inside bolt locations giving maxim strength and preventing all cap walk.
Slight clearanceing will be needed on the oil pump as seen in the pic but is also needed when just using studs..
873.82$ shipped in the lower 48. Message to order.
The oil pump will not mount without grinding the pump body as seen, this is also needed if someone only uses a stud kit... the pump body is really thick in this area so the pump is not in danger .... unless someone goes wild with a grinder....
