New product line
Twisted Steel Performance
Pauline, SC
I now have custom steering shafts IN STOCK ready to ship.
I dropped my supplier due to poor quality and service using off shore parts, so I now make these in house using 100% US made parts, Borgeson joints & shafts, each end is welded and plug welded for safety, they have a rubber boot to prevent dirt and water from entering the shaft, they have a pin that prevents the shaft from pulling apart, they have the anti rattle plate inside as well.
These are much higher quality than the stock rag joint shaft, and no part is a cheap off shore item. I personally build these and Tig weld them.
Available for 73 - 99 trucks, burbs, tahoe in stock length, if your truck is lifted contact me and I can provide you with one in the needed length..
