bison
A snubber is a restrictor prior to a gauge to eliminate fluid pulse spikes so the gauge needle stays steady.
Those fuel reading with a basically cold engine ??? if so the cold advance is coming into play, once it warms up what does the rate go to?
Those fuel rates are way too high at idle, needs to be about 8-9mm3. take a screenshot at a normal warm idle, and then copy it and paste it up here. Screenshot is in the dashboard view, then you go to file and open screenshot. Got to see it all to understand where the issue might be coming from. And if things are different, also post up a screenshot of when its running rough.
You have no way of controlling IP output, it is done electronically.
Holy crap, your idle temp is way too high. Is that what the temp gauge shows too? If that is correct you have a cooling problem. Like is there water in it?
Fuel rate is way too high too, doesnt make sense. pull the glove box out and pull PCM out, open up the hatch on the back and see if the EPROM is aftermarket. Ive seen something similar before with a bad aftermarket program. And at a minimum get the 4 letter code off of the chip.
Is that TDCO a positive or a negative value? If positive that is not good.
Pulse width is too long, should be less than 2.0.
And why is intake air 166 at idle? Is that sensor wrong too, is it drawing air from under hood?
So you have a PCM (or sensors), PMD, or IP issue.
