New mod.... "I LOVE LAMP"
Status
Not open for further replies.
If you actually do research you will realize that most LED's arent good for long distance because of the reflector.... people like vision X have polluted the market with 2nd grade reflectors for top grade price.... Rigid holds the patent from Duracell (who can only make flashlights now)... this light has spots on the side and flood in the middle and it reaches pretty far.... if you buy cheap autozone LED lights they wont shine that far either... but this one is pretty bada$$ for distance.... that was the major complaint from UTV and sandrails guys was they outran the light... this company has a trophy truck that at 120mph across the desert the light was still working fine for him.... so there is a huge difference
Psst. The star and the light are both crooked. Look at how they line up against the holes in the grill. ;)
that's how I saw it......follow the line of grill holes...the drivers side goes lower than the passengers side...
Actually its the star thats crooked.. I took it off and put it back on and I havent been straight since... I'll be taking it off for good soon enough
No one will ever notice. Tell all these guys to go pound sand, or take it off and keep it in the closet- it's up to you.
Like the light, not the price. :eek:
If people can't tell it's a half ton gasser by the sound or the 6 lugnut bolt pattern then they should not be looking at the truck.
no one can believe its a half ton gasser.... I should throw a 14 bolt under it with a 12v cummins and really make people think....LOL
I took a gander and it doesn't look the grid is square. Follow the very top part of the grille frame, you'll see the holes don't symmetrically go across the top.
I think it looks good but those RBP grilles are way overpriced IMO. If they didnt come with the star and maybe had black bead bolts, I think it would look better. The truck is set up nice though. I bet that 4.8 aint so peppy anymore either turning rubber that big...How is the Edge working so far on that motor? Can you feel any difference? Its minimal, I know but did ya feel anything or dont you drive it enough?
you cant see the 6 lugs, they are covered up, and if its not running, the only give away is if you know chevy's and see the grille is 2" smaller, or you look and see its a 10 bolt....
the edge actually makes up a lot for the big tires.... when I re-gear it I will be able to tell big time how much more power it gives me.... and you can get the RBP grille without the rivets, I just thought they went well with my flares
Status
