New IP installed now P0251 & P0370
Maybe, if you are up to changing it Heath can send you just the OP. Sure would be a lot less hassle.
:thumbsup:
Optical sensor needs to be set up properly on a test stand.
If not, you can end up with issues like a messed up "optic bump" causes.
An unserviceable optic sensor is cause for IP replacement at garage level.
I'm not saying you can't do it, I'm saying you shouldn't.
If I had just paid mega bucks for a new IP, I'd be looking for a replacement one not a piece of it.
Now, if it was an old IP already on the engine and the OS crapped out I'd give replacing it a try.
I have faith Bill will figure it out and/or make it right....
Optical sensor needs to be set up properly on a test stand.......Now, if it was an old IP already on the engine and the OS crapped out I'd give replacing it a try.
Yea I should have qualified that remark. If the pump was working fine, the OP is now suspect, and is sill mechanically timed as in not moved.... odds are better bla bla
