dave_
Hello new to this site
Once upon a time....
Back in May this year i bought a 1995 chevy suburban 6.5 which was a non runner and had been for four years! Previous owner said it needed a new injection pump
Not knowing alot about these as im from england i researched info on how to install a ds4 IP. firstly i purchased a remanufactured IP from america with a 1 year warranty that was fully tested with all new electrical parts replaced and brand new pmd. After installation / timing etc with scan tool thinking anything was running smooth the truck then frequently started stalling and showing codes 18, 35, 54! after many weeks of stalling and arse twitching driving discovered lift pump / oil pressure switch was bad causing ip to overheat due to lack of fuel maybe. after replacing both OPS and LP thinking we cured the problem, stalling still continued!
next step cleaned all known earths etc and put some 2 stroke oil in fuel and some diesel additive! stalling came less frequent, however eventully the truck would not start. we sent IP back for replacement under warranty thinking it may be the culprit
different ip unit was sent back to us, at present i have just installed the new reman IP, but still no fuel coming out of injection lines. tryed known working pmds, tryed everthing i did the first time i installed it
checked all fuses, relays, grounds. the ****er still wont run! i have a switch for on / off for LP and in dash fuel gauge showing 7 psi with lp running. theres plenty of fuel going in and out of ip. no error codes at present. also numerous electrical tests found on the web
Has any one got any advice please
david
david
