ak diesel driver
6.5 driver
Just tie wire or bailing wire
That's interesting and a cool video. I think I'd miss not being able to control the amperage while welding. I'm not good enough to select the proper amperage before striking an arc and/or compensating mid-weld. It's a really interesting concept though, thanks for sharing!
Here's a cheap Tig for you Nate
Oh, and regarding the cooler flush. After sitting for an hour, I dumped the xylene out. Interestigly it was cloudy white. I then poured the acetone that I had in there and swished it around good after sitting in there. It came out clear. It looks nice and shiny inside so I think it’s fine now.
It isn’t there in all applications so I don’t think it should affect anything - especially since it was fully concentric so there wasn’t any weight being swing around.I assume it doesn't matter that you ground off that snub on the crankshaft and doesn't look like much but was thinking if it may throw off the balance if it was intended to be there?
Last time I flushed an AC system, I’m pretty sure I just used ethanol.If you are going to flush oil coolers, heater cores using while using Evans, etc. you should treat them like AC components and use AC flush solvent and AC flushing equipment on them.
So, if you used ethanol I bet you were feeling pretty good and what did you flush the A/C system with, or can't you remember because you were using ethanol? LOL!Last time I flushed an AC system, I’m pretty sure I just used ethanol.
I knew I was going to screw that up! It was denatured alcohol that I used.So, if you used ethanol I bet you were feeling pretty good and what did you flush the A/C system with, or can't you remember because you were using ethanol? LOL!
Right on. There was another iteration that was $46, but those were all gone.I would've thought it was way more than $70. Nice find.
That figures.Right on. There was another iteration that was $46, but those were all gone.
Dang! Some of the stuff that’s left is reasonable, and then some of the stuff is RIDICULOUS. I think they wanted $20 for a replacement bulb for the dash.parts for my forklift are skyhigh the parts that are available keep going up in price the fewer that are available. If I can figure out who makes them I can get them pretty reasonable . They wanted $400 each for the last 2 wheel cylinders left. They looked like regular wheel cylinders off a pickup
I think got a house light bulb I can sell you for $10. [emoji23]Dang! Some of the stuff that’s left is reasonable, and then some of the stuff is RIDICULOUS. I think they wanted $20 for a replacement bulb for the dash.
I think I’ll pass..... Don’t worry, I didn’t actually buy those bulbs.I think got a house light bulb I can sell you for $10. [emoji23]
Sorry I couldn't help myself. Some times the smart ass in me won't stop. [emoji41]I think I’ll pass..... Don’t worry, I didn’t actually buy those bulbs.
