Rodd
Recruit
I just got done installing my egt, turbo, & fuel pressure gauges. The problem is the turbo gauge is hitting 6 psi max. I didn't hook up my scan tool but I know the boost is higher than it reads. WOT maxes out at 6 psi. Aside from the gauge being the problem where should I look for the problem. Could a slight bend or kink in the hose cause the problem?
Thanks,
Thanks,
