ghostrider500
Always stirrin' the pot
Finally got my act together and swapped out my fan clutch with a Hayden severe duty, my OEM 9 blade 20" fan with a Dmax composite, and new AC Delco stats. First, I have a side by side comparison of the swapped parts:
Then the old on top of the new. Not much of a difference, but I had to shim the turbo "silencer" to make sure it stayed out of harms way. I should just delete it. New fan fit in with no trimming.
When I went to clean the gap between the rads I was treated to a rats' nest that had to surely be choking the life out of my truck.
Cleaned it all out, sprayed water and cleaner through the rads left in place, and cleaned the big radiator outside. A before pic of the radiator:
Buttoned it all back up and installed the new AC Delco stats. Now my gauge stays stuck on the big notch between 160 and 210 no matter what I'm doing with the truck although I haven't towed the fifth wheel with it yet. Happy it all worked like it should.
