New and need sugestions/help
To save some money in the short term the 3 1/2" exhaust will suffice, you can do your own alignment, I just did with this thread. http://www.thetruckstop.us/forum/sh...a-GMT400-(or-any-vehicle)&highlight=alignment
What brand name is on the injectors? Some of SS diesels parts are OK.
Almost forgot, Welcome to TTS
Not sure on the brand But they are in the box that came from ssd only markings on them (just opened it up) are M-311 are these ok or should I look at getting something different?
This is what i believe I have http://www.ssdieselsupply.com/products.html?pid=269&PHPSESSID=59b8e727eb685aa9aaa5efa09554fcc5
Also I just ordered a new DE turbo back exhaust for $230 and a 2.5" mandrel bent crossover (with all new mounting hardward and gaskets) for $86 along with Harmonic Balancer and pulley fuel filter and the bosh glow plugs.
I would try them as you have them already.
Just a heads up, you can't link to a non supporting vendor.;)
Have the injectors pop tested before you install. Make sure they are within 5% of each other and have them set at least 2200psi
