New air compressor.
your kinda power shy. Personally I wouldn't put more than a 60 amp panel in the garage off your 100 amp home panel. Most larger 220v welders use a 50 amp circut. If you do get a bigger compressor you could max out your 60 amp panel if your welding and the compressor kicks on. I have a 200 amp service and my wife can tell when my compressor kicks on
I might just have one plug for welder and compressor so I have to switch then. That way I know I won't have issues.
That is what I am doing. It is a pain to unplug and replug, so I am putting in an switching disconnect that will only send power to 1 at a time for now. Same boat, tiny main panel and until the meter/main combo is upgraded, I cant feed my shop correctly.
AK hit it just like I would have said. Start with the mains...
Knob and tube, btw not two. As in wire runs around the knobs and through the tubes. I have renovated a few homes from that.
Gotcha. Its such nasty wire with the cloth coating. I like the switch disconnect idea.
