BigBlueChevy
Compression Ignition Addict
Bearings and races are of a matched pair as they wear together. Never leave the old race in and just replace the bearing as this will create an uneven contact face between the rollers in the bearing cage and the race. Its nothing you and I will see by the naked eye, but it has been known to cause premature bearing failure (Can you figure out how I learned that one?)
Bearing races can be removed with a slide hammer and appropriate set of jaws. I do believe even harbor freight sells said kit. Of course, Snap On sells that kit too but... $$$
Which snap ring are you having trouble removing? The orange one as soon as you pull the axle shaft?
