Acesneights1
some kind a squeal or noise.
Get a Visteon (brand) replacement. These are OEM or better quality and will drop right in and go to work.
I have purchased 2 of these so far this summer. One for DaHoooley and recently one for the 94 Burb.
Both rigs had the factory radiators that were just used up.
I paid $235 for mine (Jober pricing as I bought it through my company) They are still not too high a price over the counter though.
These radiators will do the best job you can get without going to a custom unit for the BIG $$$$$$$$$$$$$$$$$$$ The core size is the limiting factor here. Thicker is not always better. The stock radiator is a large 3 core aluminum with plastic tanks.
I hate plastic but they do seem to hold up fairly well.
My 94 Burb had 270K on the original and the only failure was the upper hose bib broke off just behind the clamp ridge and it started leaking.
Still cooled fine though.
Missy
Last thought on the subject. Any thoughts on heat extractor hood scoops? Like Missy said, there isn't a great deal of freedom for the air to escape once it comes through the rad, I bet that engine bay is kind of a pressurized area at speed. Give that air heated on it's way through the radiator somewhere to go, and the flow should be better, right?
I too ended up wit a Visteon radiator. My original went over 300K before the core corroded enough to start leaking. The plastic tanks were original and intact, so they outlasted the core. Got mine from the local radiator shop that I've done business with for years. He did tell me that this radiator is the same one O'Reilly and Auto Zoo sells with a lifetime warranty and for less than what I paid. Yeah, I know, dumb to pay more, but the guy has always been honest with me and does great work when he can fix one, so I bought his. Mike
I just called AutoZone, and they say their brand is not Visteon, but "Spectra Premium / Radiator For your 1995 Chevrolet Truck Tahoe 4WD 6.5L Turbo Diesel 8cyl"
I also thought it was funny when I did the lookup for the Tahoe, it said:
" * Available engines
o 8 Cylinders K 5.7L TBI (found in 99% of 1995 Chevrolet Tahoe 4WD)
o 8 Cylinders S 6.5L Turbo Diesel (found in 1% of 1995 Chevrolet Tahoe 4WD)
Yep, only 1% of Tahoes have the 6.5 in it....
-Rob
I see that "RockAuto dot com" has these, VISTEON Part # 9579 for under $300. Is this a reputable vendor?-Rob
No problems with the "Spectra" rad and for $160.00, you can't go wrong.
Where are you finding these?
-Rob
