Anyone have any more info? I need a whole carrier and not sure which I am going to go with. I guess mine thought it was funny to crack:mad2:![]()
Yes it is from my suburban. From what I can tell I have a 14 bolt full floater g 80. I have 373 gears. I am looking for something that will hold up to spinning both tires like at the track. Yes this is my dd and I did hear that the Detroit lockers works great. I did not price out a air locker or ect. Something I can lock myself.:thumbsup:
thanks for the input.
The only thing I disliked about the Detriot locker is that it had quite abit of play in it after you parked when you let off the brake it would roll a couple of inches. That was with 36" tires and 410s.
I wish I had a little more lockup at lower speeds for plowing.
What speed does the G80 lockup at?
I changed my fluid out to synth and never added a friction additive, what should I use?
the G80s do have clutches. trust me. i found a million pieces of them in my diff last year. not fun. from what i have been told, if synthetic is used, a friction modifier is not needed. something in the synthetic that dino doesnt have to make up for the modifier
I don't think you need a friction modifier for the G 80. The eaton uses a clutch type system and that's why the additive is needed. The G 80 is just gears with weights. Once it get's spinning to a certain speed (around 30 mph) the weights move causing it to be unlocked....I think that's what I remember being told. The G 80 never seems to lock immediately for me...it takes a bit of spinning first from my experience.
that's the problem with the G80's when drag racing...if you break traction at over 30mph it will not re-engage...
Problem = Right rear outer tire worn about 1/3 more than the other 3....even the right rear inner is OK......My RPO codes show I havw the G80 with 4.63 on 19.5's.
Too many left hand turns?
