handcannon
I've been searching for dimensions of the Mercedes 2.4 N/A diesel motor, unsuccessfully. I don't have a motor readily available for measuring. This motor has a very strangely shaped oil pan, nothing like american cars.
From pics the pan appears to be two piece. The upper portion seems to be an aluminum casting, most of which appears to be not much larger than the swing of the crank and is totally enclosed on the bottom. At the front end the pan is open on the bottom and splays out wider than the block. This portion has a stamped steel sump on it.
The measurements I'm looking for are horizontally from the bellhousing mounting surface to the front of the fan blade, the vertical height from behind the oil pan sump to the highest point of the complete motor, and horizontally from the back of the oil pan sump to the front of the fan blade.
Any help, links, etc would be much appreciated. Thanks!
Don
Don
