Need help!! Have 02 gmc 2500hd lb7 duramax transmission is in limp mode!
Coltonwalters
Petal Mississippi
I have an 02 lb7 it has been ever deleted straight piped everything else is stock as far as I know other than me buying a bully dog gt tuner and installing on the truck but 4 days after tuning it with bully dog trans went to limp mode and screen on tuner is saying it’s limped to 4th gear… I have replaced the valve body all shift solenoids pressure manifold switch internal & external filter pan gasket and all new fluids.. once I got it all back together and drove truck it shifted perfectly as if it was a brand new transmission made it about 51 miles with it working perfect and as I went to slow down to turn off interstate it went back to limp mode… after that I have replaced the Netrual safety switch have changed the speed sensor on t case haven’t replaced the other 2 on trans yet and have also changed the tcm out and it is still in limp mode I have also checked all ground connections and have checked the entire harness from tcm to transmission and even replaced the external solenoid harness plug on trans where harness plugs into and can not figure it out.. would be greatly appreciated if someone could help me out with it because it has became a major head ache…
Welcome to the forum CW.
Dd You try doing a search within the forum for similar situatiins ?
Has the PCM/ECM thrown any codes ?
I know nothing about Allison transmissions, maybe someone with more knowledge on tje matter will jump in.
With checking the codes with gt tuner the only 2 it is continuously through even after I clear them is the P0700 tcm ,P 0380 glow plug/heater circuit, and P1621 control module term memory
First code P0700 TCM.
Thats the one to start with, first in line.
The following search takes us on many routes, seems the second route would be the first and most sensible, in My estimation.
That route leads us to checking all of the connections to the TCM and the PCM.
Using whatever tools is necessary to scrape, scrub or wire brush each and every terminal in each connector so that they are clean and shiny. Then use a nice corrosion preventive on each terminal, do not use any form of dielectric silicone compound. That stuff promotes insulation values.
Instead I use this Truck-Lite compound very sparingly.
Or better, if a parts house or hardware store has some of this.
Then see how it performs.
