Need gauge/speedo/instrument cluster
Potluckslammy
Arkansas
99 Chevy C3500 6.5L Diesel. Odometer is inop...and I messed it up trying to fix it! Need replacement cluster FOR DIESEL. 150K miles, or less, much preferred...as this is the estimated true mileage. Thanks!
I've got a couple of odometers if thats all you need. An auto cluster will work just fine in a manual truck, you'll just have the gear display there not lit up.
Yes, just the odometer not working. Probably was the drive gear...maybe. Tried fixing it, and now the numbers are jumbled, and it still doesn't work!
