Matt C
Recruit
- Messages
- 59
- Reaction score
- 14
My 95 6.5 is at it's old ways of pissing me off!! lol When i go to start it it takes a good 10-15 sec of cranking to get it to go. Smoke coming out the pipe the whole time cranking. Yesterday i had to crank for 15 sec, wait a bit so the glows would cycle fully again, and then start cranking again. When it does come to life it barely runs for the first few sec till all the cylinders start working. I checked the glows, which are Kennedy quick heats, and found 2 bad ones. I checked the compression while I was in there and all cylinders are around 300, which seemed a little low but at least there all the same. I had a bunch of codes, 96 which is cyl 6 imbalance, 83 & 69 are TCC codes due to the fact I have a switch so im controling lock up myself when towing. The rest were 31, 32, 33 which are EGR & Baro codes. I noticed that one of the solenoids was making some noise so I should probably fix that. My batteries arn't the greatest so thats gonna be my next step, but it does seem like it's cranking fast enough. The temp each time was in the 30's-40's. It deffinetly seems to be getting enough fuel do to the fact that it smokes durring cranking. Possibly PMD? It's still on the pump. Suggestions would be great! Thanks guys.
