Odlaw
Redneck
Thats what I've heard about the flush. I'm still flushing the old school way - with whatever that oily crap was they came out with first....when everybody started converting to 134a.
R134 should make no difference. I have done many many conversions. The only time is an issue is if you use PAG oil and the system wasn't spotlessly flushed. I personally don't like or use it. I use esther oil. It can mix with trace r12 without damage. I was under the impression that R134 was ozone freindly but then again I remember reading that R12 wasn't as bad as they thought anyway. I don't use it simply because of cost. They had an r12 sub out for awhile that had propane/r22 and some other crap in it. I used it for a little while and every system I put it in came back next season needing a compressor so that could have biased me towards Sandens. The Yorks didn't. I stopped using it anyway at that point and wouldn't touch a system unless converting to R134. there's nothing wrong with it. I just a conversion last week on a Ford L8000. 41 degrees out of the duct.
I charge it as high as I dare, and even put an aux fan on the front to try to get more air across the condenser when moving slow. .
