confused
Recruit
I got the passenger side head off and this is what i found. First i found 2 bent push rods, then when i got the head off, the messed up piston with the pieces of steel laying on top. This does not explain the antifreeze in the oil, (3 gallons of oil when i drained it). Where do i go from here? Do i need to take the other side off? Is it worth fixing?
