My ongoing interior swap
Starting taking more parts out of the Tahoe today. Got the wiring harness for the headlights/running lights out. Need it for the sensor for the outside temp in the overhead console. (Does anyone know if the wiring parts would be in my cab to plug and play the inside harness?) I plan on taking it from the Tahoe just in case. Also would the cluster from the Tahoe work in the pickup?
Also going to cut the headliner behind the pillars,
and hopefully the map lights will be able to fit.
If the mirror wiring is in the cab , the plug will be just above the steering column down by the pedal area. If the Tahoe is a gasser than no go on the cluster.
I'll look for the plug thanks. :) it is gas. Thanks for the answer. It was worth a shot as a spare. What is the reasoning? For my info and who ever reads this. :)
