Due to others experiencing leaks with ARP head studs I used blue thread locker on the second engine I built. I used red thread locker on the first. Despite attempting to blow the heads off my engines with FOD going through em, 24 PSI boost, EGT at 1550, extreme abuse to get up the dammed 7% grade that goes for miles while towing in 121 degree F weather, and severe overspead bending valves: the ARP's are worth it due to zero HG and/or head bolt failures. I have had the heads off at least three times and saves the cost of garbage TTY bolts. My only regret is using Red as I have to pull the engine, now, to get the passenger side head off. The studs have been in for 7 years now like this.
Simply put Blue threadlocker and snugging the studs in solve the ARP leak problems. I respect the "overkill" others do, but, it's unnecessary.
TTY bolts and Head gaskets are worth about 200K give or take before the HG gives it up on average. Recall this throwaway engine is only one step above the Olds 5.7 diesel hand grenade. Yeah, do the ARP studs.
Gapless rings. I am not the first, however, I am the first to document how much soot the gapless rings keep out of the oil. It literally takes a 2500 mile oil change interval and makes it 5000 miles. You can always pay a machine shop to install the rings for you. Here is the link to my results with gapless rings. At 3000 miles I can see the marks through the oil on the dipstick. The oil isn't coal black 30 seconds after engine startup. https://www.thetruckstop.us/forum/threads/total-seal-gapless-rings.29135/
There is a lot of power available by porting the heads. You MUST do a turbo because the OEM turbo is an "Asthma Attack" that restricts airflow so badly that any improvements are lost if you don't have a better turbo put on. As you have a Manual Trans with a nasty RPM drop between some gears a "tight" turbo is way more important than with an auto trans. You need to decide on use and where you want the power at. Towing turbo's generally don't spool up before 2000 RPM. Thus you need to make sure what RPM range the turbo builder says the turbo works in. The standard ebay HX40II and ATT both need 2000 RPM to do any good. The vendor building your turbo for you is the one you take the word of.
