neura
checked the vacuum lines and no visible cracks, the wastegate solenoid is hard to move at an idle, the lift pump seems to be working fine. went for a longer drive after clearning the codes to see what might come up. Now I have the following codes.
33 44 45 48 87. so changing the baro sensor added code 33 which suggests low vacuum, the sensor we put in is a ACDELCO Part # 2131545 (the one on the firewall). wondering if this is actually the map sensor on my truck, but this has a vacuum port and my current map sensor does not have a vacuum port. 48 seems to point to the IAT sensor, and code 87 is transmission, changing the trans fluid this week when the filter kit comes in... distributor had no stock for them.
