neura
So i was kind of looking for another engine for me 93 1 Ton and happened across a K-2500 Ext Cab Long Box, minor body damage on the driver side cab corner, it's a silverado with all the options. Guy said transmission was missing 3rd and 4th. I ended up paying him $300 for the truck and hauled it home on the trailer. Got it down off the trailer last night put a plate on it and went for a drive... well it seems 3rd and 4th are actually there. so I pulled all the codes last night there is a bunch of them:
29, 32, 33, 44, 45, 48, 57, 62, 85.
It came with a spare intake, 2 injections pumps, 3 pmd's, and a spare turbo. Someone has wired in a high idle switch as well to idle it up. I need to fix the steering column as you can't pull it all the way down to 1st.. it binds up somewhere I figure probably in the tilt. minor issue.. anyways he told me he was running down the highway at 120KM/H and it wasnt in OD so he went to move it up into OD and went to far and into Reverse for a split second and then back into OD. so based on that information I am expecting to maybe do a Tranny... but it slips just a tad and has all of the gears. This truck also has a 3" straight pipe. just shy of 539KM on the dash currently. no smoke on cold start or warm start, a bit of black if you step on it, but no other smoking issues... sounds like it is going to explode when you first start it and then it settles right down. (my nieghbours 6.5TD blazer does this as well).
My 93 dosnt sound like that at all, but it smokes on startup, and even has blowby out of the oil dipstick after being shut down for 15 minutes. that is going to be another thread though.
So I guess where do I start with all the codes and getting this thing running and driving right. I might sell the 1 Ton after I get this one up and running good, or give the 1 ton to my brother in-law...
