One more shot of the motor in its final resting spot, fits in there perfectly.
The remaining shot of are of what I had to cut or "massage" on the truck. I hear alot of people talk crap about the 6.5 to cummins conversion, saying you have to smash up your truck and cut it all up and it barely fits:rolleyes5:, You absolutely dont have to cut or smash anything if you dont want to, I did so I could fit the motor in the best possible spot in the truck as low as I could and as far back as I could.
I had to shave a little ear off the old stock 6.5 engine mount pad as pictured, so i could fit the motor really low, with having to worry about any rubbing.
I pounded back the 3/4" lip where the firewall joins to the cab, to free up some real estate, no nessacary but it looks better without the pointless lip there, and I have more clearence now.
Finally I cut the top of the core support, its either that or remove it all together to put the motor in. Its alot easier to just cut it than remove the whole thing, and I still have the front structual support. I am going to make a bracket so I can just bolt the piece I cut out, back in when I am done, this way it will make it easy when I remove the motor in the future for internal engine work.
I can remove all the valve covers and service the top end of the motor and do any work I may need to with the motor in the truck. It looks like it'll be easier to work on it, in a Chevy, and it is in the cab-forward Dodge design.
All I can say it really is a great feeling when things start coming together. Just wanted to say thanks to NYCEGUY, whos on a couple other forums for helping me get this far, he answered just about every question I could think of regarding this swap so far.
