3500GMC
What T F, over
Looking at the main bearing, that is VERY characteristic of 'cap walk'.. And the main web cracks I've seen MGW describe ones just like it as the 'death knell'.. But there again, I haven't any experience with Loc-n-stitch inserts.
The crank may clean up at .020. Mic it with a blade mic if you can. Blade mics will get into the grooves for a better idea of how badly the crank is scarred.
One rod is junk for sure. The other ones should be ok with resizing and new bolts. Wrist pin bushings should be looked at too, if not replaced.
