dbrannon79 & Will L. and everybody:
I removed my original lift pump today (this is the original that came with the new motorhome). It is a Delco #6443439. Only to find out that the max output is 5.5 psi.
OEM / Interchange Numbers: 25117340, 6443439
DELPHI HFP921 Specifications
Amp 10
Connector Shape/Type 2 Wires/Female
Flow Rate 30 gal/hr
Fuel Type Diesel
Gasket/Seal Included No
Inlet Thread Flare
Item Grade Standard Replacement
Outlet Degrees 180
Outlet Thread Flare
Package Contents Fuel Lift Pump, Instruction Sheet
Pump Type Solenoid
System Pressure 5.5 psi
Terminal Type 2 Pins
Type/Series Solenoid
Volts 12 vDC
So the 5.5 psi tells me that the pump is good.
Do you think that GM put the wrong lift pump on?? Wow!!
(Remember I did have the recall and they installed a new injection pump . Maybe the 5.5 psi lift pump was the problem for the recall? )
Now remember the last test I did was at the injection pump and it read 5.5 psi immediately.
So that is maxed out.
Also someone on Truck Stop stated that if my fuel pedal was "drive by electric wire" (mine is driven by electric wire) - the fuel pressure should read 8 to 14 psi.
What's going on here or make a guess ?
dbrannon79 wrote that the specs for the EP309 and EP158 - and suggested to use the EP158.
I have been carrying a new EP309 as a spare that maxes out at 8 psi and I don't think that's enough. Do you agree?
If I order the EP158 (it is supposed to give you between 8 and 14 psi). The only thing that might happen is the injection pump might feel better!! Ha Ha!
Amp 10
Flow Rate 30 gal/hr
Fuel Type Diesel
Inlet Thread Flare
Outlet Degrees 180
Outlet Thread Flare
Pump Type Solenoid
Volts 12 vDC
