Guess what thread you win this year!
I would have guessed a clogged oil filter, esp with seafoam cleaner, and been right... Yeah, but some other issues before you go through a bunch of them silly small oil filters. Wait, I will upgrade that to problem.
Oil Sludge is still a thing.
Take a look up into the engine and see if the cylinders are scored, camshaft flat lobes, etc. Pull the #8 rod cap and check the bearing as I recall they are the last in line. You will know then how bad things are. (The 6.0 LS engines would spin #7, and or #8, as the oil pickup is stupidly in the front and during a hard launch at the track the oil pickup gets uncovered and sucks air.)
Now that you know it needs an engine make him a cash offer for 'parts' and fix it up proper with a good engine yourself. IMO No reason to spend 10 seconds putting this mess back together without fixing by rebuilding the engine. Just cleaning it out will be 1/2 the rebuild benefit. These are some nice rigs and you can't buy them in good shape for a $4000 with an engine that runs and drives even with bad/bald tires.
Hit the ads for some new take off tires that fit or somewhat used and are not aged out.
