Modified 6.5 Build
Might not fit in the truck without some firewall mods. Up pipes are
2 3/8 stainless .
It's a 99 k3500. We are pulling the cab, so we might do a small body lift. Or slide the cab back,like one inch? It's also getting a custom flat bed ,which could be mounted slightly rearwards also.
Finally started this motor in the truck. It ran fine for a bit ,then dropped a cyl. When cracking the lines,barely any fuel at #2 cyl. The little fuel that came out was foamy. Can anyone guess what caused this ?
I built the pump ,it has a new head and rotor. Injector lines aren't loose. Injectors have china 311 nozzles .
It sees a prius and is foaming at the mouth with hunger?
Blocked passage in the pump is all I can think of at that point.
