chevyinlinesix
Eyre Flow Headers
would like to know this as well.
We could start a little poll up, anyone that has/had main web cracks could check their mains for alignment. I can check mine, but it won't be for a Hwhile.
I been thinking of the o-ring issue. The Swedes have been machining the BMW blocks to accept a large o-ring that has a pyramid shape and it only fits into the block. Nothing is done to the head. This ring provides a structural support for the stock head gasket that creates a dam and doesn't allow boost to push the stock gaskets sealing rings back no more than the pyramid ring is located. This way the sealing ring still seals and no special copper gasket is required. 60+psi with this setup for quite some time and no failures. The reliefs on the block for detonation blow-outs would be optional. A regular stock gasket devoid of the fire ring goes around this setup. 1500HP on the water cooled S38 motor, easily. There is plenty of meat of the top of the 6.5 decks and this would be a very cost effective modification with superior results.
I'm thinking about pulling the 6.2 and getting it oringed ,block filled and going back to stock pistons,and using my very cracked 6.5 heads,and modified prechambers, possibly even custom made prechambers out of chrome molly steel.
That would be several steps backwards.
Why is that ?
