metal cutting chop saws
The carbide blades for AL have a reverse rake to the teeth to eliminate digging in and grabbing. However, I have used regular wood cutting carbide blades, just like you. You just need to be aware of the grabbing tendencies. Using metal cap and cove for laminate tops is almost a thing of the past, but a carbide blade makes cleaner and better cuts for the joints, as long as you can keep the blade from grabbing and ruining the trim.
Don
saw in picture makita, I weld and cut for q.a.p. and we have same one it is a joke inless your cutting 1/4 or less we have one in anchorage thats 240 motor and it will cut anything, I personaly have a gas powered still 400 ts and it cuts thru anything even big stuff might take a while but no problem
